Results 1 to 4 of 4
Thread: winch question ??
Threaded View
  1. #4
    Quote Originally Posted by spring_ridge_guy View Post
    A bow shackle can also be a bitch to undo if it is put to its limits as well unlike a hook
    This should not actually be a problem if used correctly? No disrespect intended.
    When using a rated shackle you should do up the pin then undo a good 1/4 to 1/2 turn to avoid stress fusion and lockup of the pin after being loaded up in a recovery.
    Benno7 (5th April 2012)
