you can run them through the fire wall on the drivers side under the brake booster there is more than enough room as i have run everything through there just tape the wire to a straight piece of coat hanger wire or similar and poke it through the grommet there be other wires running there already so just slide it gently over the top it might take a few goes to find a way through but just keep tryingtehn look inside up around where the steering column is and take the tape off pull your wires through and then pull the coat hanger wire back through in the engine bay. this method works because i just fitted mine lat week, cheers....
