Results 1 to 10 of 20
Thread: 2.8 diesel crank belt sprocket removal
    Hi Everybody, My name is Luke and I live in Cairns. I have a '97 2.8TD Patrol.
    I have never used a forum of any sort before, so please excuse any mistakes.
    My question is : how do I remove the belt drive pulley from the crankshaft? I need to replace crankshaft oil seal.Any help greatly appreciated, Luke
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    G'day Luke, mate, just duck over to the introductions thread and tell us a bit more about yourself and your rig.
    Once that's out of the way ,someone will be along to help you, welcome to the forum .
    Cheers, the ferret.
    Patrol Guru White Elephant's Avatar
    Sep 2011
    Perth,WA
    Quote Originally Posted by lukeincairns View Post
    G'day Luke,
    As per the Ferrets request, pop over to the intor section and tell us a bit about your rig and yourself. It's just a courtesy that is asked of new members to the forum.
    In response to your question, if you have a gear puller, use that, otherwise use 2 levers and gently jimmy it off(after you have removed the retaining bolt of course) You will also have to remove the crankshaft timing gear to get to the oil seal. Just about the only way to get that gear off is to very carfefully heat it up and prise it with a couple of levers. (that's how Nissan told me to do it when I had issues removing mine) Be very careful not to damage the oil pump housing. Mine was stuck fast, even after heating it up with a blow torch. I had a spare crank shaft gear in the shed so I ended up carefully drilling 3 x 3mm holes into one of the troughs in the teeth until I was almost all the way through to the crankshaft(don't drill into the crankshaft), then gave it a decent whack with a cold chisel, which split the gear and released it from the shaft. Not the ideal way to do it, but sometimes they just don't want to play. Especially if they have been on the vehicle for a long time-mine was the original one. A new crankshaft gear is about $60 genuine form Nissan from memory. After that comes off, there is a washer/spacer and behind that you will find the oil seal. Pay special attention to the installed direction of the washer, if you put it back in the wrong way you will shred your timimg belt. Also, there are 2 woodruff keys in the crank that locate the pulley and timing gear, don't lose them! Oh, and when you put it back together make sure you use some threadlocker on the pulley retaining bolt and do it up TIGHT! Hope this helps.
    95 GQ RX RD28T LWB Wagon and stuff. www.levelsevenband.com
  4. The Following User Says Thank You to White Elephant For This Useful Post:
    lukeincairns (13th April 2012)
    Feb 2011
    Shed
    45 Post(s)
    Gday mate welcome aboard gotta friendly mob here fulla great info and advice
  6. The Following User Says Thank You to growler2058 For This Useful Post:
    another alternative is to tap a few threads in to the holes and use a 3 bolt type puller.
  8. The Following 2 Users Say Thank You to 97_gq_lwb For This Useful Post:
    lukeincairns (13th April 2012), White Elephant (5th April 2012)
  9. #6
    Sep 2010
    on the coast W.A.
    The drive gear on the crank will be very tight.
    Some times you need to drill and tap two threads (m6) into the face of the gear to use as a puller.
    Do not bend or distort the thin plate at the back of the gear.
    DO NOT use a screw driver or lever to push the drive gear off.
    Sometimes you can get away with 3 hose clips around the gear and then a puller, depending on how tight it is.
    Replace the timing belt and the tensioner and the idler while you have it apart.
    Don't lean on top radiator tank as you will snap the overflow spiggot off.
    Remove radiator first.
    Turn the motor over 4 times (BY HAND) to make sure the timing is correct.
    Check and double check the belt timing before the harmonic goes back on.
    fit the two studs at the bottom of the timing cover before the harmonic.
    Cheers, the ferret.
  10. The Following 2 Users Say Thank You to the ferret For This Useful Post:
    lukeincairns (13th April 2012), P4trol (12th August 2014)
  11. #7
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate.
  12. The Following User Says Thank You to Dhuck For This Useful Post:
  13. #8
  14. The Following User Says Thank You to Mwalker74 For This Useful Post:
  15. #9
    howed it go Luckincairns
  16. The Following User Says Thank You to Nick71 For This Useful Post:
  17. #10
    Sep 2011
    Perth,WA
    Quote Originally Posted by 97_gq_lwb View Post
    That's a great idea!
