Results 21 to 30 of 43
Thread: Guide: Wiring Spotlights to switch
    Banned
    Ok...... this is what I did with mine & it works well.
    I have a manual override switch in the dash so I can switch the rear light on at will & at the back I put a 15 amp toggle switch in line with the Negative/ ground wire to the light itself so when out camping or wheeling I can switch it on & off from the back as long as the dash switch is on.
    Most of the power draw is sucked up by the light itself so theirs not much load placed on the switch. I've run it this way for 2 years now & its never failed me yet.
  2. #22
    Expert Trolatron's Avatar
    Jul 2010
    Tassie
    Thanks guys ill post pics up in DIY when its done.
    2009 ST Wagon
    My very much missed Shorty
    http://www.nissanpatrol.com.au/forum...rolatron/page7
  3. #23
    Advanced youngseal's Avatar
    Galway, Ireland
    Thanks folks for a great discussion on relay and switchload, very informative!
  4. #24
    Beginner Dapple's Avatar
    Feb 2012
    Melton West, Victoria
    I agree this is a good discussion. I have to go and redo my driving lights now, it probably a good thing I haven't used them for driving (except for a short time to test them). My drivers side head light does not have high beam could this be belcause i don't have the relay installed? (I have checked and changed the glob)
    What would you be if you were attached to another object by an incline plane wrapped helically around an axis?
    Screwed.
  5. #25
    Hardcore
    central coast nsw
    Do you know the current draw of the lights?
    I would expect it to be less then 3 amps, if so then yes you can bypass the relay.
    http://www.nissanpatrol.com.au/forum...watts-and-amps.
    This will help ya out
  6. #26
    Advanced footsinperth's Avatar
    Quote Originally Posted by TimE View Post
    This is another simple wiring diagram to wire a work light into the reverse light.
    Will this not turn the lights on when in reverse even during the day?
    GU III ST-L 3.0L
  7. #27
    Hardcore
    central coast nsw
    Quote Originally Posted by footsinperth View Post
    Don't use that wiring schematic ,Its wrong in every way.
    Its direct power from switch and bypasses the relay.
    In fact possibly dangerous.
  8. The Following User Says Thank You to Robo For This Useful Post:
    MudRunnerTD (19th April 2012)
  9. #28
    Feb 2011
    Brisvegas
    would it be ok if there was a fuse between the + and the switch, close to the plus, and if the wiring and the three way switch were adequate for the current?
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
  10. #29
    Hardcore
    central coast nsw
    relay wire diagrame
    Cant remember relay numbers off the top of my head , it's been a while.
    sure you will find info on here earlier, probably page 1.
    The princable is the same for front spotties only you'd be connection switch to hi beam instead of reverse.
    Reverse only supplies enough power to close relay switch.
    very little is needed to do that.
    and the toggle allows you to turn it off when not needed.
    if reverse was wired without switch,new light would come on each time you select reverse.
    direct connection to battery + terminal, then to fuse and onto relay is the new power being transfered to your new light.
    hope this helps.
    cheers.
  11. The Following User Says Thank You to Robo For This Useful Post:
  12. #30
    That Wiring diagram has now been removed by the original poster. Here is a reply by Yendor on the following page for your info.
    The problem with this circuit diagram is you will have the load of the light running through the toggle switch.
    You are better of having the relay switch all of the load.
    Such as connecting
    Terminal 85 of the relay connect to earth
    Terminal 30 of the relay connect to battery via a fuse
    Terminal 87 of the relay connect to the work/reverse light
    Terminal 86 of the relay connect to the centre/common terminal of your toggle switch.
    One side of the toggle switch connect to your vehicles original reverse light circuit.
    The other side of the toggle switch connect to a battery feed.
    If you need a picture let me know.
    I can draw one and scan it but....lol I may need help with posting it.
    Thanks to Robo for jumping on this too. Appreciate your effort keeping guys safe.
