Results 1 to 10 of 15
Thread: Bird under the bonnnet
    Advanced BEP120's Avatar
    Central Coast NSW
    Hi All,
    New to this so bear with me.
    I have a 2003 GU zd30 Patrol and the alternator stopped charging the other day so purchased a replacement from Repco down the road. The replacement is a OEX HAX070 which is labled as being the correct replacement.
    Why do Nissan make it so hard to replace something as simple as an alternator????
    Anyway I got the job done after stripping off everything around it to allow access and took it for a drive. It is charging like it never has.
    The problem I now have is that after just under 100k's the belt started squealing so put a little lube spray on it and it stopped. Next morning squealing again.
    I have checked all pulleys and the bearings are tight and noise free, I replaced the belt tensioner and belt 10'000k's ago and all seems ok there.
    I bought a stick of Dri Lube and put that on and the noise is worse. Once the engine has been running and everything has heated up the noise disappears and then comes back once cooled.
    Has anyone used this alternator on a ZD30 before and had any problems as this was the only change made to the engine before the squealing appeared. I have checked the pulley against the old one as best I could and all seems to be the same.
    My next step is to buy a new belt for Mr Nissan but don't want to spend $110 if the same thing is going to happen. Going genuine as last time I replaced the belt with an aftermarket one which was 2mm longer and had noise issues which the genuine one fixed.
    Any help or advice would be much appreciated as I am going nuts trying to locate the problem.
    BEP120
    Expert BearGUST's Avatar
    Apr 2011
    Mornington Peninsula
    Check with a straight edge that the pulleys all line up, if the new alternator sits 1mm rearward or forward it will cause a squeal.
    Also, how much lube is on the belt? Too much will cause a squeal too.
    If you can get a wire brush and lightly (and carefully) hold it over both sides of the belt while the engine is idling to clean it up.
  3. The Following 2 Users Say Thank You to BearGUST For This Useful Post:
    BEP120 (28th March 2012), gq_simon (25th October 2016)
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Does the pulley on the new alternator have the same shape channel as the original one?
    tappn it
    Hello from Under Down Under!
  5. The Following User Says Thank You to taslucas For This Useful Post:
    Central Coast NSW
    Thanks BearGUST,
    I will pull the fan shroud off again this weekend and try the straight edge and also clean the belt. While I am at it I might put the old alternator back on and see if it stops the noise. Oh what fun.
    Cheers.
    2003 GU ST-L, ZD30TD, 2 inch lift, 2.5m side awning, cargo rack, snorkel, 285/75/16 M/T tires, cargo draws, cargo barrier, UHF, DVD/CD player, on board air compressor, duel batteries, B/Bar, spot lights, 50ltr water tank, Pillar pod with egt & boost gauges, catch can, egr block, dawes and needle valves, 3" exhaust.
    Central Coast NSW
    tappn it
    Yes the pulleys seem to be the same.
    In hindsight I should have paid Mr Nissan $1000 for a genuine replacement but wanted to save my pennies for another accessory. The one from Repco was $440 as you can see there is a big difference.
    Hardcore
    central coast nsw
    New belts?.
    new belt squeal, sound like break-in stretched, needs adjusting.
    twin belts set up, should be matched sized not simply the same.
    cheers
    Expert Kelvinator's Avatar
    Aug 2011
    maryborough and gladstone queensland
    how much deflection are you adjusting your belt to? Remember to check the deflection on the side with the longest distance between pulleys. And if its a twin belt setup check between the two. More times than i can count i had customers complain that they couldn't get them to stop squealing so i was forced to take them back to single belt. They are an absolute pain if they wont align exactly. I had a car once that i really considered going to a gilmore drive simply because i couldnt get rid of the squeal of satan
    Flip er on er wheels, she'll run!
    4.2 Diesel GQ 4" King'n'ProComp Lift, 33's, Gu steer box conversion, custom drawers and a heavy right foot. Turbo kit, quarter chop and a heap of barwork coming very soon!
    A BIG thanks to Johnny at Repco Northside Rocky for always sourcing me the gear and parts I need ASAP You've saved me many times.
  10. #8
    Central Coast NSW
    Hi all,
    Well yesterday I took the new alternator back off and put the old and new new next to one another. I measured everything with straight edges and vernier calipers both alternators matched so it's not the new alternator coursing the squeak.
    Bit the bullet and brought a new genuine belt and have now put that on. The squeak has gone so will see if it comes back after a few K's.
  11. #9
    Central Coast NSW
    Quote Originally Posted by Kelvinator View Post
    The GU ZD30 has a single belt and a self tensioner. The tensioner and belt were replaced 10'000k's ago and is nice and tight so its not the tensioner or little shock attached to it.
    I have put a new belt on it see above post so am hoping that was the problem.
  12. #10
    Hardcore
    central coast nsw
    Cross fingers only a worn belt.
