Has anyone mentioned braking to you, Mudslut? To get the same deceleration tyres that size would need the brakes to exert 30% more braking torque than standard wheels. You may be in really hot water, especially if you were to have an accident on the road.
07 DX CRD Auto Wagon
Yes I am looking at getting some vented and x-Drilled rotors with upgraded pads also, I should have that part covered for a bit over $1,500. Is that the sort or upgrade you were talking about? I can't really see the room for bigger rotors or calipers in 16" rims... Unless there is a BIG brake kit that it can use with 16" rims???
Matt, 91 Patrol 4 Door Ute, 8" of lift, 35's, Low ratio diffs, Spartan Front locker.
Come Join my 4x4 club @ www.Trenchmen4x4.com
Check out my Facebook page ----> Trenchmen 4x4 https://www.facebook.com/Trenchmen4x4
There is a kit getting around from a place in WA larger rotors bigger calipers etc supposedly is a much better increase than slotted/drilled and aftermarket pads
Mudslut, the kit that Nissannewby mentions sounds to me to be a better bet than the option you were considering. The way I see it your kit would be fine if you were just trying to improve braking with reasonably standard tyre diameters in say repeated braking on long downhill sections. But the large diameter tyres are going to play havoc with the "bight" of the brakes, ie your ability to stop the wheels when you stamp on the pedal. Larger diameter rotors may overcome this, but I would caution against just changing things without getting a lot of EXPERT advice.
G'day mate,
In my opinion a 40 is too big for other than comp use, I run 35's all day and 37's on harder trips, braking is greatly affected with the 37's and i have upgraded to the twin piston calipers with slotted rotors. Also I am only running a 3" lift with the guards chopped (can supply pics if wanted) so 8" is abit unnecessary.
Lewis
Ben-e-boy (27th March 2012)
I also like the idea of big tyres small lift, for the same reason Benny said, in that it will be a more stable rig. Big lifts IMO are only useful in slow offroad situations such as wombat holes or areas where you need great articulation on a flat surface. On any sort of inclination great articulation just becomes dangerous as the risk of rolling increases exponentially.
They've done studies, you know. 60% of the time, it works every time.
