Further Developments..
A couple of weeks ago I swapped the wheels around and put the best ones at the front. This improved the pull to the left slightly, but not enough to be happy.
A couple of days ago, while driving in the wet, I heard a noisy front wheel bearing on the front left.
Bought a new kit and fitted it today.
Took the bus for a drive to check it out (like you do) and guess what.... The pull to the left has disappeared.. Bloody fantastic.
before I took the wheel off, I also noticed it was also a bit loose ( Wobbling on the axle)
So I figured the bearing was causing a bit of drag, and also being loose has probably changed the camber enough to have an effect.
To be honest, I could not imagine the car would ever have come out of the factory, with a pull to the left, so logically it would indicate that something has changed since then.
That change was a faulty wheel bearing.
So, Problem fixed....Yeah..
