Quote Originally Posted by Bigrig View Post
Sounds like the window contacts on the passenger side?? Not sure if they're on a separate circuit as such' do am thinking the button contacts are poor ,,, hmmmm
Had front pass door, then back same side.
thought this odd and probably a wiring fault.
This case Not so, just dirty rocker switches.
removed switches, opened cleaned with spray contact cleaner.
greased rockers "not" electrical contact points.
works again.
checking with test light if ya have power in/out of switches is a easy test to do.
