Results 1 to 8 of 8
Thread: Front end noise GQ LWB
    Mongrelbrook
    Hi all, Yep im new to this site and im already trying to pick your brains, My Gq has a knocking noise under braking and low speed turns which seems to come from around the drivers side floor area, wouldnt think it would be the first Gq to do so. My initial thought was the radius rod to chasis mount bushes, so i put new bushes in the rods and chasis mount, diff end were worn,also did panhard bushes, but much to my discust in not fault finding this noise correctly and getting pretty pissed when i drove down the road and it did it again, i didnt kick the truck, i bit down on my tounge and thought bugger it, ill google it! Again i was pointed straight to the patrol forum, so here i am, a new member and already i can see there would be a wealth of knowledge on here, so please to all the Gq yoda's on here, could you guys shed some light on this for me. Thanks Paul.
    Maybe drivers side CV........... hopefully one of the gurus can shed some light, coz i'm just a novice and guessing lol
  3. The Following User Says Thank You to Clunk For This Useful Post:
    Pablo76 (3rd March 2012)
    Feb 2011
    Brisvegas
    Body to chassis mounts ok?
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
    Expert stets's Avatar
    geraldton wa
    body mounts or possibly shock bushes. occasionally the sway bar connect bushes wear and cause some knocking type noise too. i have even heard of brake caliper bolts falling out and causing weird noises under braking
  6. The Following 2 Users Say Thank You to stets For This Useful Post:
    Benno7 (3rd March 2012), Pablo76 (3rd March 2012)
    Expert ozzyboy's Avatar
    Oct 2011
    springwood, qld
    sounds like same noise that just started in my GQ
    Body mounts
  8. The Following User Says Thank You to ozzyboy For This Useful Post:
  9. #6
    Mongrelbrook
    Well body mounts are the only thing that havent been replaced recently so i think ill check those out, how are you meant to check them for wear?
  10. #7
    ONE TREE HILL SA
    I recon its the sway bar mounts! Mine was knocking on floor pan type noise and new bushes fixed it.
  11. #8
    i have had knocking noises as well body mounts is what mine are now just how do I fix it. Is there any way that you can do it easily? what points are best to use to jack the vehicles body off so that I can replace them or put in rubber spaces or something?
