Results 1 to 10 of 14
Thread: how do you open a driving light?
    Expert Mazodude's Avatar
    Aug 2011
    Forest Lake, QLD
    I was having some fun (read: till gunter stopped bonnet first and floor flooded) in the pig pen at ripley and my new hid driving light filled with mud/water.
    how do you open a driving light to clean/empty it?
    "Gunter" - 1993 Nissan Patrol GQ DX II, 6cyl 4.2L Diesel. 2" Lift EFS suspension. 33" Mickey Thompson MTZ (285/75 R16). Warn Winch
    Patrol Guru Airstrike's Avatar
    Feb 2011
    Driving lights the cars or dricing lights aftermarket spotties?
    Aug 2011
    Forest Lake, QLD
    yea the spotties
    Feb 2011
    Usually most of them will unscrew counter clockwise holding the reflector housing
  5. #5
    Aug 2011
    Forest Lake, QLD
    it does not seem to want to turn :/
  6. #6
    Feb 2011
    What are they brand etc? series/ model
  7. #7
    Aug 2011
    Forest Lake, QLD
  8. #8
    Expert Big Red's Avatar
    Feb 2012
    Quote Originally Posted by Mazodude View Post
    is there a small screw on the bottom side of the chrome ring ?
    undo that, pull bottom of the ring out a bit then unhook tab at the top to lift off. ???
    You can follow me but its gunna hurt !
  9. The Following User Says Thank You to Big Red For This Useful Post:
    Mazodude (26th February 2012)
  10. #9
    How long have you owned them mate? were they turned on when you went in the water/mud? If they were on then a Hot light can cause a vacuum when entering cold water. If they were turned off then they are Junk and you should Un-Bolt them and ask for a refund at $299 per light.
    Farkem mate. Outrageous!!
    This is not your problem.
    If they are full of muddy water they are Rooted mate. The reflector is unforgiving and it is now wrecked! You WILL NOT clean it without scratching it and they will NEVER be the same again.
    Rip them off, send them back and make ALLOT of noise.
    JUNK.
  11. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  12. #10
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    if there is no screw underneath or they do not twist apart, they will be sealed (supposedly) which means throw em in the bin or send them back for a refund.
    If they are sealed, once you break the seal they will be knackered anyway.
    www.swat4x4.com
  13. The Following User Says Thank You to oncedisturbed For This Useful Post:
