Results 1 to 10 of 13
Thread: im getting 33inch cooper st on my standed GQ patrol will they fit?
    adelaide
    whit out getting a lift??
    They'll go on but they will definitely rub on your flares under any flex, or turning front wheels.
  3. The Following User Says Thank You to Clunk For This Useful Post:
    bobby-didge (17th February 2012)
    Feb 2011
    Shed
    45 Post(s)
    X2 wot he said^^^
  5. The Following User Says Thank You to growler2058 For This Useful Post:
    adelaide
    cheers for that guys
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    I've got 33" cooper stt's. Have a 2" lift that is old so a bit sagged and they fit just nice:-)
    Hello from Under Down Under!
    Patrol Guru Warnie's Avatar
    Apr 2011
    Muswellbrook NSW (formerly Brisbane SEQ)
    Sorry guys but I do not completly agree. Everyone forgets the most import part when it comes to tyre debates, Offset. They will fit and will not scrub if the correct offset rims are with the combination. If going on standard GQ offset rims (0mm) they will scrub at the rear under compression and may touch the radius arm at the front at full lock (mine did). If a larger offset (again depending on rim width - 24mm on an 8 inch rim or -13mm on a 7 inch rim) then they should not scrub.
    Just my 2c worth
    They've done studies, you know. 60% of the time, it works every time.
  9. The Following User Says Thank You to Warnie For This Useful Post:
    bobby-didge (22nd February 2012)
  10. #7
    Aug 2011
    North West Tas
    56 Post(s)
    I got new rims when I got the coopers and they are 15x8inch dynamica (sunrasia). Not sure what offset to be honest I didn't ask! They fit fine.
  11. #8
    I also have a 2in lift with 33" mickey t atz's on 15x8 rims.... Not sure of offset. When fitted they rubbed on the front mud flaps mounting bracket, so took the flaps off until I find something better. They also rub very slightly on the standard rear flares under flex but rub on nothing else. Time to fit some bunnings flares
  12. The Following User Says Thank You to Clunk For This Useful Post:
  13. #9
    Feb 2011
    Shed
    45 Post(s)
    And I got 33" on 15x8's also no idea on the offset with a 4" lift and they scrub on articulation on the rears (no swaybars tho)
  14. #10
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by growlers71gq View Post
    Gets no better as you go higher - I got a 5" lift with 33"x12.5" bighorns on 15" rims with -22 offset and they still rub the upper inside of the rear arch .. could always extend the bumpstop I guess ...
    Nahhhh ... lmao
  15. The Following User Says Thank You to Bigrig For This Useful Post:
