Results 1 to 10 of 10
Thread: Lights swap Gu series 1
    FIJI
    Will the crystal headlights and corner light from the later model GU bolt-on to my Gu series 1 or will it need some kind of modification??
    I believe a series 1, 2 & 3 will fit but be careful, generally little changes in the models will be made to the headlights?? Check before you buy mate. Ring Nissan and ask them to check the part number for a series 1 2 and 3 headlight, if they are the same you have your answer.
    FIJI
    looks to be the same but thought to ask in the forums if anyone has done the swap previously so i can be sure about it before i buy.
    FIJI
    no one did this swap??
  5. #5
    We are about to just bought the series three lights as they are the better ones but should just swap straight over will next weeked when we do the swap
    Cheer Hunty
    Gu 4.2TD Wagon Tourer with the goods :-)
  6. #6
    FIJI
    Great!! please let me know how u go about doing it! if its straight swap i might wana get mine done as well including the rear tail lamps. Cheers
  7. #7
    I've been wondering this for a while now, just seem to have found the answer:
    Look forward to your pictures and confirmation
  8. #8
    FIJI
    Awesome! Thanks for the link Beddu! so i will go ahead with the swap! but i noticed in the above link the side indicators had some water vapours inside.....non-genuine lights issue i guess
  9. #9
    Straight swap mate no problems
    Cheer Hunty
  10. The Following User Says Thank You to Hunty For This Useful Post:
    Aben Dean (15th February 2012)
  11. #10
    Well, to confirm, they fit:
    Ish.
    And now protecting the investment.
    Need to be aligned though, as one headlight is currently doubling as a Airplane spotlight. This is what they replaced.
    Also, hi, I'm new :]
