Results 1 to 7 of 7
Thread: Wet Carpets
    Expert nickpeacock36's Avatar
    Oct 2010
    North Lakes Qld
    Thumbs down Wet Carpets
    Can anybody suggest the best method of drying out my GU carpets? the water crossing i did on Sunday was a little deeper than i bargained for. I am trying to dry it by leaving the windows open through the day, but it is still sopping wet in there and i think it will start to get a bit smelly if im not quick. It is muddy water by the way.
    Thanks in advance for any help.
    Patrol God wildgu6's Avatar
    Sep 2010
    Adelaide S.A
    Hey buddy, seats out and if you can't take carpet out for a few days, chock it up with some timbers, bricks, what ever you can get in there to raise it and let some air flow in there.
    x 2. even if you can't be bothered taking the seats out take the carpet up where you can put chocks under everywhere and leave the doors open too.
    I have been known to sit back for an hour or so with the hair dryer under the carpet too...lol
    Feb 2011
    Brisvegas
    saw a car detailer get seats and carpets pretty wet while cleaning same, then he got stuck into them with a wet/dry vac. Probably not as wet to start with as a flooding in a crossing.
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
  5. #5
    Oct 2010
    North Lakes Qld
    Thanks for that guys
    I have raised the carpet as suggested and the car is sat at home with the doors open. hopefully a little drier when i get home.
  6. #6
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by nickpeacock36 View Post
    I had a mobile bloke come around and do mine after I flooded it - bought the carpets up trick, and took (no joke) just shy of two full buckets of water from the apparently only wet carpet - my point is if you've flooded it, good chance there's a lot more water in there than you may think ...
    Yours is a nice truck and I'd be getting a wet/dry vac into it (he steam cleaned mine after also and it was like coffee going up the pipe).
    Good luck with it mate!!!
  7. The Following User Says Thank You to Bigrig For This Useful Post:
    nickpeacock36 (8th February 2012)
    Oct 2010
    North Lakes Qld
    I ended up removing most of the insulation / soundproofing as the carpet is rubber backed and pretty dry.it Will be much easier to dry out if it happens again.
