Yep they were super hot Im talking loose your finger print if you touch it hot. I wasnt resting my foot on the brake pedal Im too lazy to keep my foot up there when crusing the highway
see I was maby 10 minutes from home and I could here a squeel from the brakes so I would dab on the pedal and it would stop then a few ks it would do it again and that happened 5 or 6 times so had a look at home and found all was cooking.
I pulled the other side caliper off today and I would say the piston is pushed out as far as the rubber boot will extend and I cant push it back in by hand...is that normal?
Also opened front caliper on one side and that piston is also unmovable..Ill post up more pics tomorrow.
