Results 1 to 5 of 5
Thread: Full leaf sprung gq ute: will greasable shackles soften the ride?
    Nov 2011
    My ute rides a bit rough and saw these on ebay:
    http://www.ebay.com.au/itm/NISSAN-GQ-PATROL-GREASABLE-SPRING-SHACKLES-BUSHES-/32072758358pt=AU_Car_Parts_Accessories&hash=item4a acda8b62
    Just wondering if anyone had a good experience from fitting greasable shackles and pins? $200 seems pretty cheap considering to keep them moving you should probably take apart/clean/grease every couple of years (pig of a job) but the big question will i notice a difference? i am pretty sure the fronts are starting to stick cause if you hit a bump quick enough you get a squeak and they look like oem rubber bushes whereas the rear has poly bushes. Just wanting some input before i lay down some clams.
    Advanced jc58nc's Avatar
    May 2011
    Batemans Bay NSW
    I did the same thing with my MK SWB, it did help a bit but if you want to have a softer ride remove 1 or 2 of the main leaves as well
  3. The Following User Says Thank You to jc58nc For This Useful Post:
    bobbrumby (4th February 2012)
    Expert MudDonk's Avatar
    Underwood
    a set of parabolic leaf springs will make a big difference with ride and flex bob
    Nov 2011
    ok got a set of shackles on the way. would the lmm grease i use for the uni's go alright with the bushes?
    Quote Originally Posted by bobbrumby View Post
    The greasable shackles will give yo a nicer ride but mainly it will give you a quieter ride. The grease you use on the Unis will be fine.
