Results 1 to 4 of 4
Thread: GU Patrol Dash fixing for Hema HN5i
    Beginner saa3011's Avatar
    Brisbane
    G'day all
    I have a standard Hema HN5i mount that I was hoping would fit into the dash of my GU (pics (from carsales.com) attached I hope). Problem is, the dash lid flips up and is perfect for a sun shade to the screen, but the base of the mount is too big to fix inside the "mini glove box".
    Does anyone know of this being tried before and how the problem was overcome, or has a Hema been fixed here in some other way - maybe an after market dash surround??
    Steve
    Attached Files Attached Files
    Alternatively run a strip of velcro hook along the bottom edge of the Hema and an alternate strip of Velcro Hoop stuck to the bottom of the Pen holder in front there and it will stand there forever. When not needed remove the Hema and the hoops stay put. You can move to access teh glove box and / or lift the lid for shade.
    Simple and you can get rid off the bulky mount that wont be required.
    If it sits too low into that grove then get a piece of 20mm x 20mm pine from bunnings and stick hook and hoop to that as a booster seat. You might consider fitting a 12v plug into the glove compartment so you can just run your lead into there when needed to.
    Just a thought.
    I have a GUIV also and had that glove box out last weekend, simple to get to and out and there is room to run 12v to it.
    When you have it sorted post some pics mate.
    Cheers MR
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    saa3011 (1st February 2012)
    Advanced bindi's Avatar
    Apr 2014
    Gippsland
    Quote Originally Posted by saa3011 View Post
    G'day all
    Steve
    Hi Mate
    did you ever suss this out, I am thinking about doing the same
    cheers
    Mark
    Brisbane
    G'day Mark no I didn't work it out. The main thing was not cutting into the dash box so I ended up just using the windscreen mount.
