Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Learn from others mistakes
    Advanced mitchelljames's Avatar
    Nov 2011
    sydney
    battery welding looks like it could save some serious time, have you ever had to use the method
  2. #12
    Sep 2011
    adelaide
    18 Post(s)
    welding some photo`s
    The diff photo`s were taken on the Anne Beadellat about the SA WA boarder the job lasted to Laverton and the back to Adelaide .
    The caravan drawbar was done just north of Thargomindah and was redone and gusetted at Windorah
    as a safety precaution as he was traveling to the cape and then back to Adelaide.
  3. #13
    Expert teleman's Avatar
    May 2011
    Montrose
    My hats off to you Plasnart. You have turned this thread into a great thing. Everyone get on it!!!
    2001 GU series II 3.0 TD.
    2" lift
    Dual Battery System
    ARB Snorkel
    Awesome car!!!!
  4. The Following User Says Thank You to teleman For This Useful Post:
    Plasnart (28th December 2011)
  5. #14
    Patrol Guru rottodiver's Avatar
    Nov 2011
    Perth
    i have one which recently slowed me up..... i was on some very corrugated tracks for about 50 km,s and the tied rod nuts that lock the tie rod in place vibrated loose..... consequently the tie rod started to turn, being on on rutted sand it took a while to notice till the steering wheel had turned so dramatically then hit some harder stuff and geeze did i notice, it toed my wheels right in... i then jacked the front end up, packed out a string line from back wheel to front wheel, and measured the distances untill i go close as i could.... then tightened the nuts... it got me home but ruined one of my front tires but i was home.... so when you get a wheel allignment my suggestion is put a good few wraps of 100 mile and hour tape around them and the thread if going to be doing any kind of corrugation!!!!
    hope this saves some of you some time and rubber!!
    Scotty
  6. The Following User Says Thank You to rottodiver For This Useful Post:
    Shaunous (6th January 2012)
  7. #15
    Nov 2011
    sydney
    Thats no good scotty , well at least you got home mate , cheers for the tip
  8. #16
    Feb 2011
    Wheelers Hill, Melbourne
    By far the handiest thing you can have on outback trips is a travelling companion (in another vehicle). This enables sharing the load of safety equipment to some extent, and enables a stuck vehicle to be towed out, winched out, or snatched out.
    You should also carry food, which no-one has mentioned Carry high density foods like nuts, oats, dried fruits, baked beans, etc - things that will keep you alive without requiring water for preparation. (Rice, for example, is compact but requires lots of water to prepare).
    There's nothing on earth more relaxing than camping in the outback - unless it's camping in the Vic High Country or the Tassie highlands.
