Couple of good points in the thread so far.
Firstly to answer the OP... I don't have any pics but know of several people who have installed Hayman Reece recievers into Bullbars. In every case it was done for the ease of manouverability of reversing trailers and vans into tight spots/difficult driveways.
Personally I would NOT recommend them as a Snatch Strap (I stress Snatch Strap) recovery solution as at least one of the recent fatalities in the last two years was a lass killed by part of the Bull Bar failing. The method would be perfectly fine however for winch/tow/driver assist type recovery tho.
Snatch Strap ratings - The Snatch Strap (which are rated in Breaking Strain by the by) rating should be 2 to no more than 3 times the weight of the lightest vehicle in the recovery regardless of whether the lighter vehicle is the bogged or recovery truck.
Bent Front Chassis Rails - Usually occur for 1 of 2 reasons.
First reason is in a 'single point of attachement recovery' is an inordinate sideways pull IE not Fore and Aft.
Second reason is in a 'bridle attachement recovery' and is due to people not understanding a force multiplier phenomenon called 'Sling Load Angle'. If the bridle is too short and the 'Load Angle too high' it will actually multiply the force of the Snatch Strap or Winch by potentially as much as 6 times and change the force vector onto the Bridle IE attempt to pull the rails together rather than the vehicle forward out of the bog.
Hope that makes sense... I'll hand the soapbox over to someone else now![]()
