Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Front wheel spinning while 4wd is disengaged
    Feb 2011
    Brisvegas
    Someone has to ask, and it might as well be me.
    Plenty have thought they were in 4x4 high, but had not moved the short lever............. could this be the opposite situation?
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
  2. #12
    Sep 2011
    Abbotsford , BC Canada
    Quote Originally Posted by toddrhind View Post
    Spot on Paul, all four wheels on ground stall testing, seen the marks on his driveway this arvo where both rear and front passenger wheels spun.
    I missed that. I agree, the issue is not likely the hubs. If you are sure the gear selector is out of 4H and the linkage is okay, then it is likely a tcase issue. When last did he have it in 4WD?
  3. #13
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by Silver View Post
    hahahaha, I had a day sorta like that, went out for a play with some mates, was tired as and shouldn't of been driving. On the way out we had 2 recross a river crossing which has a very rocky bottom........I got stuck halfway across! reverse forward reverse... I was going nowhere. My mate started 2 walk across the river which was freezing cold 2 hook up the snatch, then one of my other mates yells out..........Put it into 4wd.....I looked at the dash, sure enough 4x4 light not on......mmmm I'm sure I had engaged 4wd, sure enough I hadn't Done the river crossing on the way in and all the tracks in 2wd, mind you the tracks weren't that hard
    My mate that walked into the river swore and cursed me for a few secs then had a good laugh, glad he found the funny side of it all.
    Lever in correct position, but as Paul has advised the selector is worth a look, as my Dad has a feeling its been like this since he has had the 4b
    Todd
  4. #14
    Aug 2010
    17 Post(s)
    Quote Originally Posted by canuck View Post
    Gear selector is out of 4H/4L but still need 2 check the linkage. Not sure when he had it engaged last, but considering he doesn't use his 4wd as a 4wd I would assume a while ago.
