Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: OME Question?
    Quote Originally Posted by gavinsell View Post
    Thanks Clunck71
    my truck measures the same.... i must have a 2" lift... I dont like they way it sits higher at the back. could i get a longer spring?
    I think if your's measures the same as mine, you could possibly have heavy duty springs fitted on the rear........... do you have a steel or alloy bull bar and do you know if the previous owner did a fare bit of towing? I don't know if there are any identifying marks on the springs to say what rating they are, maybe there's a sticker on them with a parts code?
  2. #12
    pottsville beach nsw
    Hi Air bags for crd ,what is a good brand
  3. #13
    i have seen adds for firestone,are the ok
  4. #14
    an american site has them for $110 plus $60 for postage,i have been quoted $345 at tjm
  5. #15
    Aug 2011
    Quote Originally Posted by clunk71 View Post
    i have a steel bull bar and brush bars that run into the side steps. i know the previous owner did not tow not much at all but maybe the owner before that... what are my options when it comes to bringing the front up level? could i put a longer spring in it or would i have to put new shocks in the also??
    I'm not really sure to be honest mate, I'm far from an expert on such matters and am only learning myself....................... like I mentioned before, you may possibly have the same sort of set up as mine, standard duty up from and heavy duty at the rear.............. having a harder set up at the rear will make its back end stick up a bit higher, until you start loading up the boot that is, then will level up.
    So you can either change the rear springs to a lighter duty or the fronts to a heavier duty. If it was me I'd leave it............. but that's just my opinion
  7. #17
    Feb 2011
    Shed
    45 Post(s)
    To get the most from your suspension i would get springs and shocks that are matched/compliment each other ie a shock that will extend/compress to the flex available from the springs if that makes any sense
  8. The Following User Says Thank You to growler2058 For This Useful Post:
    gavinsell (20th December 2011)
  9. #18
    Aug 2011
    thanks clunk71 im definitely keeping the back shock as they are as im going to put drawers in it.. also do you have 33" tires on your truck or do you think they would fit?
    I don't have 33's yet, they're next on the list but know plenty of people running them with 2in lift no problem
  11. #20
    Aug 2011
    33's are also my next on the list... thats great that they fit. happy mam.
