Results 11 to 20 of 28
Thread: Gu 2.8 hot start issue ?
    Expert patrol2.8's Avatar
    Nov 2011
    vic
    Picked up the o-ring and plate last week hopefully will fit it this arvo or tomorrow morning dont know if this is related but have found that having some fuel in the sub tank car seems to start better when its hot
    Theres only one thing tougher than my truck............. YES DEAR GOING TO DO THE LAWNS NOW
    WARNING: Towballs used for recoveries,can and do kill people and damage property
  2. #12
    Nov 2011
    vic
    Ok jus got around to doing the hot start fix found it was really easy took around 20min to do and that was with taking pics so should take around 10min have uploaded some pics of the job this is how i did it
    1) remove the battery opens area up and allows easy acess to plate
    2) undo the 2 bolts holding the plate and remove plate and o ring
    3) install new o-ring and plate tighten up the bolts
    4) Re install battery start the car check for leaks
    easy as that
  3. The Following 6 Users Say Thank You to patrol2.8 For This Useful Post:
    brucemacca (12th April 2012), davidgu (4th October 2012), jman69 (30th April 2013), MrAz (23rd March 2012), the ferret (2nd August 2013), Where2fromhere (15th June 2014)
  4. #13
    Jul 2013
    I know this is a very old thread, but can anybody tell me where i can get those parts?
    Or show me a link to a website or email where i can order the parts ?
    Best regard.
  5. #14
    Quote Originally Posted by Aparass View Post
    Best regard.
    Parts are from Nissan.
  6. #15
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    You can get the required parts from "nizbits" a vendor on this forum.
    Cheers, the ferret.
  7. The Following 3 Users Say Thank You to the ferret For This Useful Post:
    jman69 (2nd October 2014), patrol2.8 (5th August 2013), Where2fromhere (18th May 2014)
  8. #16
    Shellharbour NSW
    Hey guys, thanks for the info. I'm going to get in touch with Nizbits, but wanted to get a heads up on what the plate an 'O' ring actually do? My 2.8 cranks over for ages, initially on cold then both hot and cold. Once it's running, there's no problems at all so I don't think it's a fuel supply issue. It's got me completely stumped
    Any suggestions would be fantastic.
    Thanks in advance, Mark
  9. #17
    Sep 2010
    on the coast W.A.
    Quote Originally Posted by Where2fromhere View Post
    Sounds like you need to replace the glow plugs AND the advance plate, go genuine glow plugs tho.
    The plate and 0 ring replaces the existing plate, it has a raised section which advances the pump.
    Cheers, the ferret.
  10. The Following 2 Users Say Thank You to the ferret For This Useful Post:
    patrol2.8 (19th May 2014), Where2fromhere (15th June 2014)
  11. #18
    Shellharbour NSW
    Hey guys, after all that, it was the timing in the pump that was out and had nothing to do with the crank angle after all. It turns out that a $40 timing advancer for the fuel pump from Nizbits was all it took. It's starting better than it EVER has. There are a couple of good threads on here about the fuel pump advancer and how it's fitted. Thanks everyone for the input and feedback.
  12. #19
    Shellharbour NSW
    Garry from Nizbits was really helpful. The pump error was a factory issue and supposedly issued by Bosch a few years ago. He sent the part and info sheet which I've kept with my vehicle manual. Excellent result all round.
  13. #20
    Jan 2015
    ireland
    hi guys, this is my first post, so here goes, i need to het my hands on this advance plate for the rd 2.8, but cant source the part in ireland, can anyone please please help me. we have very little or no info on this fix in europe. by the way, i have more than 100 zd 30 patrols breaking, and have a good knowledge on zd30, and would be happy to answer any questions
