Results 1 to 1 of 1
Thread: How to check the stall speed of your torque converter
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    1) Warm the engine and transmission up.
    2)
    Put it into drive with foot on brake and accelerator flat to the floor.
    3)
    Check to see what the maximum revs are e.g 1800 or 2000rpm etc. on your tachometer
    This is your stall speed. Do this test as short as possible as it produces a lot of heat.
    If you know what your lock up speed is meant to be and it revs past it or just revs up to redline then the torque converter maybe faulty.
  2. The Following 3 Users Say Thank You to NissanGQ4.2 For This Useful Post:
    AB (9th December 2011), Oka374 (14th December 2011), wheels (8th December 2011)
