Results 11 to 20 of 42
Thread: Power A/T Button
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Quote Originally Posted by mudtrolluk View Post
    Down is "Hold" green light shortens the shift, so will change gear to a higher gear quicker helping with traction and restricting engine power.
    Not 100% sure about gear changes but in mine "hold" also means take off in second gear. Like a snow mode you take of in second for better traction
    ________________________
    ______ 2017 D-Max _______
  2. #12
    Middle is "Auto" no light, standard shift pattern, however if you boot it, it will change to "Power" on its own and show orange "Power" light until you back off.
    My old R31 Skyline used to automatically shift to power mode when you booted it, but I've never noticed my GU do it. Although I don't usually look down at the switch when I boot it-Skyline 'power' light was in the instrument cluster.
    Tony
  3. #13
    Expert Cadbury's Avatar
    Nov 2010
    Waterford QLD
    Yes, it does help thanks, You talked about a Haynes manual, do they do a manual for a 1999 GU 4500 petrol auto?
  4. #14
    Advanced mudtrolluk's Avatar
    Nov 2010
    Essex, Uk
    Quote Originally Posted by YNOT View Post
    Tony
    Not 1999 however all patrol’s seam to follow the same rules of thumb or very similar technology; Tony’s skyline had a similar gear box control by the sound of it?
    I’ve won every drag race of the lights for 7 days, I love snow, ice and my troll
  5. #15
    Nov 2010
    Waterford QLD
    I am not sure if maybe I have a blown fuse or something more serious, as no lights cpme on in the different positions and I cant see any difference in the gear change either.
  6. #16
    Is the switch connected?
    Tony
  7. #17
    Nov 2010
    Waterford QLD
    Good point. I will check that first.
    Man I sure will look like an idiot if that was the problem hey.
  8. #18
    Expert Chaz's Avatar
    Sep 2010
    Adelaide
    In HOLD mode, the transmission won’t use 1st gear. It holds it out of 1st gear for low traction surfaces such as snow, ice or mud. You can still shift into 1st manually, but in "D" you will start off in 2nd gear with the Hold switch on.
  9. #19
    Feb 2011
    Pretoria, South Africa
    My Patrol doesn't have this switch. What do I need to install a similar switch in my car and can anybody help with a circuit diagram?
  10. #20
    It should have a switch from factory if it's an auto. If it's there it will be on the centre console. Retro fitting the switch would only be possible if the wiring is already there.
    Tony
