Results 1 to 10 of 17
Thread: Noisy clutch pedal
    Sep 2011
    Noisy clutch pedal
    Anyone experienced a noisy clutch pedal on their GQ when its depressed. Like a kind of clicking noise coming through the pedal arm itself. I've sprayed the whole area with lubricant and it didn't do anything. Its annoying as all hell. Help!
    Feb 2011
    Brisvegas
    Not I, touch wood! Intrigued though.
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    A worn thrust bearing maybe ?
    Banned
    Quote Originally Posted by BigMav View Post
    From time to time I do..... Its the pin that holds the push rod clicking in & out of the groove its warn in itself over use.
  5. The Following User Says Thank You to patch697 For This Useful Post:
    BigMav (7th December 2011)
    Feb 2011
    Shed
    45 Post(s)
    Opposite mate I get an intermittent knocking sound that goes away with either slight pressure on the pedal or full depression and slowly release and it stops. Tho will return at the next set of lights
    Feb 2011
    Brisvegas
    growlers, I reckon that could be the thrust/throwout bearing slopping about on the shaft
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by Silver View Post
    Ahhh bumma don't really wanna be pullin the box out:-(
    Feb 2011
    Brisvegas
    Quote Originally Posted by growlers71gq View Post
    My MQ did it for years - mechanic mate said not to worry about it, so I didn't. Mind you, I wasn't taking it into the desert etc - just Fraser and Moreton Islands etc. Now, I don't know enough to say that is what the cause of yours is, or whether you can or should safely ignore it - but it did work for me
  10. #9
    Sep 2011
    Quote Originally Posted by patch697 View Post
    This sounds interesting, going to have to take a closer look, mine was doing it only on occasion but seems to be doing it all the time now, its not the thrust bearing the noise is definitely coming from the clutch arm somewhere so my money is on that pin. Cheers.
  11. #10
    Feb 2011
    Shed
    45 Post(s)
    Wadda they say ignorance is bliss :-) I'm gunna ignore it for now
