Yep, That is pretty much the simplest way to do it. I never had any hassle with the GQ's certainly (have never done a GU) and the LED was enough to remind me to switch it off.
Because the GU's will stall if you do forget you can always add in another relay from the Brake Pedal switch to disarm the circuit (same as how Cruise Control interlocks).
