Results 1 to 10 of 10
Thread: home made body lift
    Advanced dirty_dog's Avatar
    Aug 2011
    Kelmscott, WA
    home made body lift
    could i make a homemade body lift by cutting up a nylon pole and drilling holes through it. os that abit dodgy. it's just that the body lift kits seem so expensive for what they are.
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    Yes you can, lots of the kits are nylon anyway, they need to be 75mm minimum diameter tho.
    75 mm nylon shaft does cost a bit too, depending on the grade.
    Then you need to replace all the bolts for longer ones.
    If you go to a turning shop, they often have off cuts of acetal or nylon, that's where I get mine but I also have a lathe.
    Cheers, the ferret.
    22 Post(s)
    just go to bcf and get boat rubbers they have a crush tube in them as well
    96 GQ coil/Cab
    08 G6eT
  4. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    megatexture (18th March 2012)
    Oct 2011
    How did u go with it dirty_dog did u complete ur modification?
    is it legal to make ur own lift kit?
    Sep 2011
    Abbotsford , BC Canada
    Boat rubbers? Can you give a bit more information? I am not sure what you are speaking of but I am interested to see if I can find something the same here in Canada for a 1" body lift.
    Quote Originally Posted by canuck View Post
    Try something like this mate
    http://www.amu.net.au/boat-rollers.html
  8. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    canuck (10th November 2011), megatexture (18th March 2012)
    Sep 2011
    So just take a straight roller and cut it down to the height I need? Sounds like a very good idea. Thanks again.
  10. #8
    Advanced twinotter600's Avatar
    Nov 2011
    Cantley, Quebec
    Boat rubber! Now that worth looking into. TKS>
    Safari Hoarder
  11. #9
    Nov 2011
    is alloy or synthetic better for bodylift?
  12. #10
    Advanced flemj's Avatar
    Apr 2011
    Riddells Creek Victoria
    Try this link
    http://www.amu.net.au/body-lift-bloc...an-patrol.html
    Has the body spaces already done
    John
