Yendor
Tracking down the cause of noise in the radio can be a real pain.
I would start by checking/cleaning all the vehicle earths, especially the body earth points, (I have heard a story about how radio noise was stopped in one vehicle by running an earth lead to the bonnet).
Normally when alternators are the cause of the noise the sound heard is a whining type noise that increases with engine RPM, you could try fitting a noise suppressor to the main power wire at the alternator.
How's your vehicles ignition system? how old are the plugs, leads, cap and rotor button? these can cause noise, you could also try fitting a noise suppressor to the positive side of the coil.
You could also try disconnecting the aerial from the back of the radio and see if this stops the noise.
Another thing you could try is running the power supply directly from the battery (both power and earth) just temporary run some double insulated 4mm twin from the battery to the radio (connect both the battery back up and accessory wires to power and earth to the radio) and see if this stops the noise. If it does stop the noise a relay will need to be installed when the wiring is done permanently.
Hope this helps.
Good luck with it.
