Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: electronic rust proofing?
    Jun 2011
    Rockhampton Q
    yah i've heard there good i priced a 6 pad ERPS they want $1000
  2. #12
    Expert Thirsty's Avatar
    Oct 2011
    Raceview, Ipswich QLD
    I sold a 10 pad erps today (fitted)for $985 and 6 pads are about $885.
    1998 GU TI LS1
  3. The Following User Says Thank You to Thirsty For This Useful Post:
    sr06 (4th November 2011)
  4. #13
    Jun 2011
    Rockhampton Q
    where do you work then? is it worth the trip from rocky lol
  5. #14
    Oct 2011
    Quote Originally Posted by sr06 View Post
    UV4X4 Enoggera, proberly not worth the drive.
    Good luck though
    1998 GU TI LS1
  6. The Following User Says Thank You to Thirsty For This Useful Post:
    sr06 (1st November 2011)
  7. #15
    Hardcore
    central coast nsw
    Don't waste your money on electronic toys that simply dont work.
    More than enough info on web , waste of $$$$.........
    Stick with traditional methods.
    Oils, waxes. Elbow grease, only method that works.
    Tip-
    Never put a high pressure cleaner near a car, forces water and what your trying to remove into places you don't want it.
    Always,low pressure.
    As low as possible enough to do the job of rinsing off only.
    And stay away from auto car washes, they recycle their water,how many guys have been to the beach today?? salt/chemicals in the water!!!!.
  8. The Following User Says Thank You to Robo For This Useful Post:
    growler2058 (4th April 2012)
  9. #16
    Tweed heads
    the 1999 gu st i picked up has an electronic rust protector installed, but due to poor maintainence from the last owner there is rust in some places.... i reckon the electronic protectors work, you just have to look after it as well
  10. #17
    I just removed a 10 pad erps system from a rusted out gq .
    It had rust repairs previously and had been sitting 4 years with a flat battery near the beach wich obviously didn't help.
    Wondering if it is worth fitting into mine.
  11. The Following User Says Thank You to 97_gq_lwb For This Useful Post:
    Robo (5th April 2012)
  12. #18
    Hardcore
    central coast nsw
    These toys need a wet surface for the current to flow across the metal panel.
    And due to the fact the power used is so minimal you need a pad on every small panel.
    and a few on larger panels.
    Thats the reason 10 pads had to come off the rusted out car.
    So unless you own a submarine forget it.
    They do not protect against chemical corrosion never ever.
    salt will attack a metal panel ever minute of the day.
    The flat battery had nothing to do with it
    this is a whole other process that small current/power can not tackle.
    Stop wasten your money fellers and stop believing the cleaver marketing.
    Fact-- chemicals and power are actually use to strip metal clean in the metal plating industry.
    admittedly higher power and acid but I think you follow what's going on.
    and don't forget salty water is a mild acid even creek water can be corrosive.
    just an example to help you understand what's realy going on.
    I know this for a fact as I have a plating kit and do exactly this to clean metal of rust and/or old plating.
    leave process running to long and you keep on losing good metal.
    "we used this to protect our mines 4x4 and it worked a treat".
    stop and think do they keep these vehicles, the answer is no never.
    just work shops with unlimited budgets.
