Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Rear wiper motor shorting
    Aug 2010
    Mandurah South, WA
    Sorry it's taken me so long to get back to this thread.
    The problem was that the voltmeter picked up it's supply from the rear wiper motor switch on the dashboard. One of the sparkies at work had meggad 'a wire that was live with ignition' for me to supply the voltmeter with - rather than run it from the battery and it being live continuously.
    Is there a better source for the supply to the voltmeter? Please advise. Thanks
  2. #12
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by Aquarian51 View Post
    This is not genuine, someone must of rewired it this way. They normally run off different fuses.
    The voltmeter (like any gauge) is just a guide, so any ignition feed will do.
    Doing this I don't think you are fixing the problem, just covering up the symptom.
    I still think you have a voltage drop issue.
    Did you check the earths?
  3. #13
    Aug 2010
    Mandurah South, WA
    Does the voltmeter also drop when you use other electrical items such as indicators or when headlights are turned on?
    If so I would check the main earth that runs from the negative side of the battery to the body, is it clean and tight?, also I would check the main earth for the dash, from memory it connects in the panel around the inside fusebox.
    Does the rear wiper move slowly or is jerky in it's movement? I would try lubing up the wiper mechanism as per Paul post.
    The voltmeter only dropped below 8 volts (the minimum reading) when the rear wiper actually wiped, so it was an intermittent drop of voltage. The wiper just did a steady slow wipe of the window. It dipped of course when the glow plug was engaged, but when the engine started the volts were pretty consistent around the 13-14 volt mark.
    I did what Ben-e-boy suggested and disconnected the motor and the voltage drop still occurred, which indicated that it was a wiring issue - not a motor problem. That's when I decided to follow the wiring from switch to wiper and realised the voltmeter was using it as its power source.
    I checked the earth connection from the battery and dashboard, and lubed the wiper motor.
    I've disconnected the voltmeter from the wiper wire, so it is not connected to anything at the moment, while waiting for advice of maybe a better 'ignition source' to connect to.
