Results 1 to 10 of 38
Thread: No Auto electrician will touch it.....
Threaded View
  1. #14
    Oct 2010
    Old Bar, NSW
    Snicko, I'm an electrician and have done a bit of this wiring on my own gear.
    The advice is good what is above, please be really carefull of 240volt in your system. I assume you have an inverter 12vdc to 240vac.
    And there is an inlet plug, that one is easy - make sure the lead is not plugged in.
    As for the inverter
    If it has a power point socket on the outside - unplug the lead. Then disconnect all 12vdc from it and make safe.
    That 240volt stuff is leathal and you can not see it, so be very carefull when de-wiring components.
    Allway check twice!!!
    Good luck with it
    Macca
  2. The Following User Says Thank You to macca For This Useful Post:
    snicko (15th October 2011)
