Results 11 to 20 of 22
Thread: Does This look After-market???
    Aug 2011
    Kellyville, Sydney
    2003 GUIII ST-L and mine looks like the above, with a different switch in the upper right. It was a blank until I swapped it out for a 3-way switch for my work light. Put the switch there so I could reach through the window to turn on/off the work light easily without having to climb into the cab.
    Dimmer switch is on the dash just to the left of the steering column, with the driving lights switch (factory steel bar with IPF 900s) next to it.
    You should be able to pop the switch out and check for cabling. If you can't, then remove the lower dash panel below it (one screw on the LHS bottom, 2 screws in each of the pull tabs for bonnet and fuel filler, then lift up from the bottom) and you should be able to look up past the fuse panel into the void behind that switch plate.
  2. The Following User Says Thank You to Bagheera For This Useful Post:
    MudRunnerTD (24th September 2011)
  3. #12
    Patrol God wildgu6's Avatar
    Sep 2010
    Adelaide S.A
    Definately an after market buddy, what its for ???? could be as mentioned above for driving lights that you dont have ??
    I have one similar but its different spot for sub tank, as original sub tank switch needs resetting every time i use turbo timer,
    Too hard so it stays luminated and i just use the after market switch
  4. #13
    Expert teleman's Avatar
    May 2011
    Montrose
    Nah man. The light does not come on, so thats one of the reasons why i thought it was a half finished job.
    2001 GU series II 3.0 TD.
    2" lift
    Dual Battery System
    ARB Snorkel
    Awesome car!!!!
  5. #14
    Expert the godfather's Avatar
    Mar 2011
    Piara Waters, WA
    My dimmer is there as well. Are you sure it doesn't turn your dash lights off or on?
  6. #15
    May 2011
    Montrose
    Quote Originally Posted by Finly Owner View Post
    OK Teleman, I take it with a name like that you can fiddle with switches and wiring easily? Pry it out gently and check for wires as mention by others. Then go to under bonnet and have a look for 4 wires either with spade terminals or cut. They may be tucked away or just sitting waiting for connection.
    Tim
    You would be correct Tim. I will post findings in the next 3 days.../ when i have time off... hehe. and still need to get the nads going...
    Cheers.
    2" lift
    Dual Battery System
    ARB Snorkel
    Awesome car!!!!
  7. #16
    Beginner webmast3r's Avatar
    Sep 2011
    Brisbane
    mate i'd say the old switch got pushed in too far and its been replaced with a new one, def looks out of place but the only way you'll know what its for is if you pull it out... tinker tinker tinker
  8. #17
    Aug 2011
    Mine has the dimmer on that spot also, and the cruise on / off switch just below it.
    I think some models also came out without a dimmer, that switch is definately aftermarket,
    most likely for lights or something.
  9. #18
    Sep 2011
    I had the same switch in the same spot it was for spot lights, it was good i didnt have to do new wiring
  10. #19
    May 2011
    Montrose
    SO, i popped the switch out and found it was a;l wired up!!! I then popped the bonet and scouted around. I found the same wires sealed and cut short in the top left hand side of the engine bay. Looks to me like ive got a half finished drivng light job. Woo Hoo. Less work for me!!!
    2" lift
    Dual Battery System
    ARB Snorkel
    Awesome car!!!!
  11. #20
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by teleman View Post
    Good stuff mate - either half finished or removed previously - either way, less work for you as said!!!
