12th October 2011, 10:22 PM
12th October 2011 10:22 PM
12th October 2011, 11:27 PM
Moderator
yep that wire would be fine. Remember though you can grab an earth from the back of your car somewhere so you really only need to be running the positive all the way from the front. The bigger the better to reduce voltage drop mate for a compressor. they can draw a heap. Go Large. Single wire would be fine, save yourself some cash.
![Cool](images/smilies/cool.png)
Check out my Toy -->
Rogue Dung Beetle
13th October 2011, 09:37 PM
MudRunnerTD
Thanks mate Ill do what you said and run just the one wire and pick up an earth at the back.
Cheers Ray
28th October 2011, 09:47 PM
im a bit puzzeld as to why you have lights on the bottom of ur set up ,the draws will cover ,oh dont worry i get it doh its upside down oh boy ,its beer oclock i think ,nice touch mate
28th October 2011, 10:09 PM
Make sure you put a fuse in the line close to the battery, that way if any part of the power cable gets shorted out you are protected.
Tony
28th October 2011, 10:23 PM
this is what i ran 6B&S. I placed a fuse block with earth connectors at the back end, to connect all my accessories to.(Fused separately, based on requirement). also agree with AB Fuse at battery, that 6 B&S can carry a fare bit of juice and you don't want that finding its way to you.
Scotty B | Take it Off Road or Take it Back
3.0L GUIV 2005 - TIG Welded Intercooler, NADS, Redarc Dual Battery, Additional rear power socket, 2" Lift (Ironman constant load foam cell), Electronic Trailer Brake Controller, Steel Bullbar, 12,000lb Winch, UHF
2nd November 2011, 08:47 PM
[QUOTE=YNOT;156814]Make sure you put a fuse in the line close to the battery, that way if any part of the power cable gets shorted out you are protected.
Thanks guys. Im going to put this breaker close to the battery.
2nd November 2011, 09:08 PM
#8
Patrol Guru
very very nice..love your drawer mate
