Hi Everyone,
Reading around the web I have noticed some info on chassis cracking around the rear spring tophats and bending of the tophats. Does anyone know if this is confined to a certain model year/s and if it was addressed by Nissan and when?
Hi Everyone,
Regards Rob
Hunting for my first Nissan GU Patrol, all input appreciated.
***Edited this post for the sake of the thread.
This is a problem across teh range of GQ and GU and is a know weakness.. Its a Biatch.
NO is the answer, Nissan has done nothing about it and likely wont. You can get a brace kit for the spring towers from Superiors for $120, Single piece. but you need to have a 2" body lidft to fit it in so a GQ with a BL is ok but not common on a GU. The Coil cab guys just lift the tray off and install them.
You can get a Weld on brace kit to that can be added to a GU but cant tell you much more about it. It will add gussets to the towers and resolve some of the trouble.
Heavy touring + Heavy load + corrugations and you win the prize!!
Superor also make a very impressive bolt in tower brace kit for the GU and it is on my list of future mods for sure. It can be donw without a body lift and is a solid bit of kit.
I have the spring tower brace plate in my GQ from Superior as seen in the posts below
Last edited by MudRunnerTD; 24th August 2014 at 12:50 AM. Reason: Made a Correction of the Information
Its a Nissan! =====> Its a Keeper!! ....... Got a TD42 in it BONUS!!....... I'm a lucky bugger! I've got 2 of em!
RJG (6th October 2011)
Ive seen the brace kit, I wonder what it would cost to have it welded in? The single piece brace would obviously stop the towers from flexing to a degree but I can see why you need a 2" body lift to accomodate it.
Regards Rob
here is a link to a list of parts from Superiors mate
http://www.superiorengineering.com.a...h=31_32_34_190
there is a few different pieces for weld on to make a kit and then the Single piece bolt on with a body life.
Hey thanks Plasnart and Mudrunner for the links and info. Have to wonder if this isnt a good bit of insurance for the longevity of the vehicle.
Regards Rob
I remember when I put the GU 2" lift in my GQ the guy mentioned that there is a slight risk of mine cracking with the GU lift.
Spoke to Peter at ATOC in Belgrave this morning it doesnt matter if it is a new or old GU or even a GQ on the lHS rear this can can occur. He welds in a steel renforcement into the rear spring towers which he claims he has never had a issue after being completed. For under $1k I might invest in this just to protect my investment in the patrol.
Regards Rob
I have just been under the back of my 2008 GU and it appears that my chassis is bent. There is deformation on both outer sides of the chassis rail at the rear of the spring tower. The chassis is also cracked both sides approx 250mm between and beyond the spring tower. I have completed a number of trips with a camper trailer, Cape York, Flinders Ranges, Simpson Desert west to East and most recently through the Victorian High Country with Billy Goat's Bluff included.
Has anyone else had any problems with cracking in this area and what was the fix?
When we were in Birdsville a few years back a Patrol that was very heavily loaded had broken the chassis and was dragging its but on the ground.
5 blokes and 8 gerrys plus swags etc on the roof, it was chokkers.
They were organising to get it freighted out, one of our mob was getting his car serviced and said the mechanic reckoned it needed a new chassis.
The passengers were trying to get flights out, which was quite a problem. We got the impression they were not talking to each other!
Fair dinkum it looked bloody sad.
A few blokes in our club have had troubles with Coil rear utes, one had the Superior Brace but he did give it a caning in the NT causing some cracks.
I have sent a link for ATOC to our Nissan owners.
Shows where to look for damage, a great reference.
Might save them some bucks in the long run. Interesting topic
Macca
