RIP - valued member and true gentleman of this forum that will be missed by many!
Feb 2011
Brisvegas
here is my earlier post on those caps
Hi,
On my GQ's trunnion swivel, the hole in which the trunnion or king pin bearing cups reside, also contains a sheet metal disc with a seal called a king pin cap. These are available from Mr Nissan (only?) and are a bit over $30 each. I suppose an enterprising type might be able to do something with a sheet metal disc and silicone, but the originals are not flat.
If I had thought more about why the opening had two little half moons on either side, I would not know how much they cost
While the manual says to remove them with a brass drift, after my first attempt, I found a suitable punch that looked remarkably like a straight blade screw driver shank did the job, because it could be fitted down neatly into that half moon slot, carefully alongside the edge seal on the king pin plug. I make no guarantees that you'll get all of yours out ok, but having learned my lesson on #1, I got the other three out ok.
