Page 4 of 16 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 159
Thread: Installing Pyro and Boost gauges in a GU
  1. #31
    Expert Leighw85's Avatar
    Sep 2011
    Perth
    awwww and here was me thinking it might be a realtive easy job to do.
    oh well, looks like i might have to get it done at the mechanics.
    cheers mate
  2. #32
    Aug 2011
    As I said above... Take it to an exhaust shop and explain that you just want the thermocupler installed post turbo.
    They are the experts at welding exhausts.
  3. The Following User Says Thank You to guterra For This Useful Post:
    patch697 (29th September 2011)
  4. #33
    Sep 2011
    Perth
    mate that sounds like a top idea
    how do i connect the rest up after they have welded that in? if its hard to get to?
  5. #34
    Aug 2011
    They will coil the lead up near the firewall on the passenger side. Just run it through to your A pillar (grommet on firewall where its coiled). All you need for the gauge is Acc or IGN, earth and illumination. Pull the head unit out and you will find it in the loom there. Just ground the earth to the metal tubing inside the dash - or any metal piece connected to it. Screw the 2 wires for the thermocupler onto the back of the gauge. Thats pretty much it. I think there are instructions in the box anyway so you should be fine.
  6. #35
    Sep 2011
    Perth
    well shouldnt i have all those wires running to the boost gauge already? I was thinking i could just solder a connection from these wires to the new gauge.
  7. #36
    Aug 2011
    Lights & earth yes, but most boost gauges are mechanical. As in if yours has an airline running into the back of it, then it doesn't need Acc or IGN to power the boost gauge. So you will have to still grab that.
  8. #37
    Sep 2011
    Perth
    the boost gauge in my car at the moment is an electric one if that helps mate?
  9. #38
    Aug 2011
    If that is the case then yes you will most likely have all the wiring there. No problem with solderig onto your existing wires. I would double check the wires with a test light first just to make sure.
    Sep 2011
    Perth
    yeah mate, no worries.
    Cheers for all that
    ordered my gauges tonight. Got the autometer cobalt ones.
    now i should get them early next week ready for the install
    might ring the exhaust place tomorrow and see how much its going to cost me to put the part in!
  11. #40
    Sep 2011
    Perth
    Ok so went to an exhaust place today. He said it can't be done hahaha said my cat converter was in the way or some crap! Tried to flog me a sports system then a chip! Is it really a massive issue or was he being a bit of a drama queen?
