Results 1 to 10 of 159
Thread: Installing Pyro and Boost gauges in a GU
Threaded View
  1. #8
    What engine are you running?
    That gauge measures Boost and Vacuum. If you have a Turbo Diesel then there is No Vacuum and it should never go into the "Negative"
    I run a boost gauge that measures in PSI and then you can make sense of what guys are talking about when they talk 12psi or 15psi of boost. Running a gauge that measures in Bar is fine as long as you understand the conversion table. Look it up on the net and using a conversion table you should find where your at.
    If you can afford it i would be ditching the Bar gauge and running a psi gauge. If you have a diesel then a psi gauge that runs boost only from zero to 30psi would be a winner. If you have a Petrol then you do need a Boost Vacuum gauge but i would still be moving to a psi gauge for ease of use.
    my 2c, cheers
  2. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    patch697 (26th September 2011), the ferret (26th September 2011)
