Results 1 to 9 of 9
Thread: geting some lift
Threaded View
  1. #7
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Here's some pics mate - hopefully clear enough. Essentially you need to raise the bracket the spring loaded brake tensioner goes onto (attached to the plate my finger is on, which is the plate/flat piece you need to raise up) - it needs to go up the same amount as the lift - that is, lift 2" and mount a 2" bracket to lift it, lift 3" and mount a 3" bracket to lift it, etc. The third photo is side on but I'm sure you can figure out what's going on. The bracket is attached to the top and back of the rear diff housing.
    Best of luck with it mate, and let us know if you need anything further.
  2. The Following User Says Thank You to Bigrig For This Useful Post:
    aaron (30th September 2011)
