Results 1 to 9 of 9
Thread: Trailor plug, easy to do?
    Expert HippoNZ's Avatar
    Feb 2011
    New Zealand
    Hi guys,
    At some stage I lost the trailer connector as I was dragging the rear end of the rig down something lol
    I need to rewire a new one, is this hard? Any one know which wire goes in what socket thingy?
    Moving house and need it back up and running to keep the law happy......
    thanks in advance
    Brett
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Quote Originally Posted by HippoNZ View Post
    Hi guys,
    thanks in advance
    Brett
    Is it a 7 flat, 7 round or 6 round?
    ________________________
    ______ 2017 D-Max _______
    ACT
  4. The Following 3 Users Say Thank You to Maxhead For This Useful Post:
    Clunk (25th September 2011), HippoNZ (24th September 2011), patch697 (24th September 2011)
    Feb 2011
    New Zealand
    Quote Originally Posted by NissPat View Post
    Flat 7, Thanks for that mate, it will save the headache tomorrow! Trust me I'm no sparky lol
    Expert beansathome's Avatar
    Nov 2010
    deception bay (QLD)
    when you buy the plug to install there isusaly instructions. also every plug i have opened up is numbered and the same from plug to plug . its not a hard job all u need is simple colercode wich nisspat has suplied the exact link i always use
    pitty your not near buy i would b happy to show u
    22 Post(s)
    Brett the manual will help you out as well . but what I would do is set my meter to ohms and test every cable to earth. once I have found the earth cable I will turm my meter to volts and the test every thing brakes, indicators etc and use the process of elimination to find everything you need
    Benny
    96 GQ coil/Cab
    08 G6eT
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    If you just need to fit a new plug, just match the correct coloured wire up to the correct pin number as per NissPat link.
    Just note, that a black wire is often used as the earth wire, if you don't have a white wire in your harness.
    If you are not sure just test each wire as per Benny post.
    Also if scotch-locks have been used to connect your trailer plug harness into the original harness I would remove these and solder the wires instead.
    If they are not causing problems now they soon will.
    a member of the menagerie MC97GQ's Avatar
    Jun 2011
    Nimmitabel in the deep, deep south of NSW
    Totally agree with Yendor on this, spent a lot of yesterday rewiring my plug on the back of the truck.
    Lights, indicators, brake lights would only work when they felt like it. The culprit Scotch Locks and 14 years of dirt, dust and water.
    Make decent connections and solder everything and make sure you have a really good earth.
    Mark
    Proud former owner of a 1997 White GQ TD42 Patrol Cab Chassis with an after market turbo, now with over half a million k's and still going strong, that's had a heart transplant and now not owned by me
  10. #9
    Feb 2011
    New Zealand
    Cheers for all your guys help and advice there. Truly appreciate it. Just got it all hooked up, tested and all worked fine the first time! however, some idiot forgot to put the plastic screw that holds the two halves together of the plug box and well lets just say its gotta come back off so I can put the screw on first lol
    Thanks again
    Brett
