Results 1 to 7 of 7
Thread: steinbauer module? any other mods needed???
    Expert grimace's Avatar
    Apr 2011
    central coast N.S.W
    g'day guys, i was looking into buying a steinbauer power-up module for my GU 2008 3L COMMONRAIL and was wondering if there would be anything else i would need to keep an eye on the engine so that i don't end up with a costly repair bill if something goes wrong. also have any of you blokes got one and if so how do they go. any info would be grouse, cheers....
    2008 GU 2" LIFT, GME UHF BLACK KING WHEELS, SAFARI SNORKEL, LIGHTFORCE 240' KAYMAR DUAL WHEEL CARRIER STEINBAUER POWER, beaudesert 2 3/4 system, runva 11,000 comp winch.....
    Legendary snicko's Avatar
    Apr 2011
    Eyre Peninsula SA
    Hi grimace. I have one on my 2006 3L Non common rail. Its a good idea to have a boost guage and a Exhaust temp guage fitted preferably before you have the chip fitted. By doing this before the chip you will have an idea what the motor is doing.
    GU Patrol: 3LTD :- The cheapest option is to buy the right thing the first time! - YEP WORKS FOR ME!!
    Front and Rear "LOCKED" WOO HOO !! squeal, scream, squeal toot toot !! hahahaha
    NISSAN PATROL.com.au .......stickers........done by Snicko.......I know you want one....
    http://www.nissanpatrol.com.au/forum...screen-Sticker
  3. The Following User Says Thank You to snicko For This Useful Post:
    grimace (16th September 2011)
    Sep 2011
    NE Adelaide
    Hi Grimace,
    i've one fitted to our GU '05 3T/D for about 15 months now. It IS a must for towing a camper trailer. My advice is to keep the right boot off the pedal, and drive smoothly and you'll have NO problems.
  5. The Following User Says Thank You to cossack For This Useful Post:
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Quote Originally Posted by grimace View Post
    A bigger exhaust will compliment the chip nicely and as Snicko said make sure you install boost and EGT guages.
    ________________________
    ______ 2017 D-Max _______
  7. The Following User Says Thank You to Maxhead For This Useful Post:
  8. #5
    Apr 2011
    central coast N.S.W
    yeah i will definately get onto that cheers snicko....
  9. The Following User Says Thank You to grimace For This Useful Post:
    snicko (16th September 2011)
  10. #6
    Expert scotty83's Avatar
    Apr 2011
    Hillcrest, QLD
    Quote Originally Posted by cossack View Post
    Hi Grimace,
    What do you mean by this?? Is there issue if you boot it?
    Scotty B | Take it Off Road or Take it Back
    3.0L GUIV 2005 - TIG Welded Intercooler, NADS, Redarc Dual Battery, Additional rear power socket, 2" Lift (Ironman constant load foam cell), Electronic Trailer Brake Controller, Steel Bullbar, 12,000lb Winch, UHF
  11. #7
    ACT
    Quote Originally Posted by scotty83 View Post
    The common rails have a tendency to cut out(momenterly) when you put your boot in, especially up hill towing. It's just their way of preventing over boost( I thing)
    When I first got mine I noticed it a lot, then with a bit of getting used to you'll soon learn how to drive them and prevent it from happening
    What I do now is drive through the gears manually and you'll tow anything in hilly terrain.
    I have no chip any more and a standard exhaust, couldn;t be any happier
