Page 6 of 14 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 139
Thread: Snicko doing the NADS
  1. #51
    Oct 2010
    Old Bar, NSW
    Sent PM Patch
  2. #52
    Sep 2011
    Melbourne, Vic
    Hey Snicko looking good, I am looking at taking the plunge with a 2003 GUIII 3L and I am trying to figure out how much it will cost to do the NADS? do you mind if I ask how much the whole catastrophe set you back? cheers
  3. The Following User Says Thank You to philws For This Useful Post:
    snicko (14th September 2011)
  4. #53
    Legendary snicko's Avatar
    Apr 2011
    Eyre Peninsula SA
    When I have the bill for Monday's work I will post up here what I had to pay for everything to do the NADS!! (no friends Snicko....hahahahaha)
    GU Patrol: 3LTD :- The cheapest option is to buy the right thing the first time! - YEP WORKS FOR ME!!
    Front and Rear "LOCKED" WOO HOO !! squeal, scream, squeal toot toot !! hahahaha
    NISSAN PATROL.com.au .......stickers........done by Snicko.......I know you want one....
    http://www.nissanpatrol.com.au/forum...screen-Sticker
  5. The Following User Says Thank You to snicko For This Useful Post:
    philws (14th September 2011)
  6. #54
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by snicko View Post
    hi snicko ha ha wont be as much as a new motor,any way theres lots of 3l running around with lots of milage on the clock
    now that you have your nads done it will be easyer to mantain only one way to find out how good it is to come on over and we,ll show you some great country
  7. The Following User Says Thank You to Sir Roofy For This Useful Post:
  8. #55
    Apr 2011
    Eyre Peninsula SA
    Quote Originally Posted by roofy View Post
    Thanks Roofy I'm working on Hubby...........hahahahahaha
  9. #56
    Apr 2011
    Eyre Peninsula SA
    As the temp was a bit high and I hadn't had the needle valve fitted today I fixed it. My trusty mechanic used his patience again and I was back. hahaha
    It's now reading 480 Degress at 15 psi full noise.
  10. The Following User Says Thank You to snicko For This Useful Post:
    patch697 (16th September 2011)
  11. #57
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    That's good snicko, you must keep it below 500, over that for prolonged period will melt pistons. ouch!!
    Cheers Rod.
  12. The Following User Says Thank You to the ferret For This Useful Post:
    snicko (16th September 2011)
  13. #58
    Apr 2011
    Eyre Peninsula SA
    Hi Guys
    Hooked the camper on and went for a drive. On the flat at 100kmh 4th gear its doing 3100 revs 300-350 degrees at 13psi. (Constant speed)
    At the worst going up hills it got up to 525 degrees at 15psi
    When we got home the car smelt really hot.
    BTW Hubby is very cross with me. The high temp melted the rubber we have on the back to stop stones when the camper is hooked up!!
    And he can't see what all the fuss is about (NADS)!! So I'm copping it!! hahahahahha
  14. #59
    Expert scotty83's Avatar
    Apr 2011
    Hillcrest, QLD
    general question. any reason why you would take the boost gauge off that side of the intercooler. i have mine on the other side.. is there any difference in readings?
    Scotty B | Take it Off Road or Take it Back
    3.0L GUIV 2005 - TIG Welded Intercooler, NADS, Redarc Dual Battery, Additional rear power socket, 2" Lift (Ironman constant load foam cell), Electronic Trailer Brake Controller, Steel Bullbar, 12,000lb Winch, UHF
  15. #60
    Apr 2011
    Eyre Peninsula SA
    What are the exhaust gas temps of a standard 3LTD 2006 (non common rail) from the factory? Does anyone know?
