Results 1 to 4 of 4
Thread: GQ home turbo job - dump pipe hits block & which lines are what on std GU 4.2 turbo
Threaded View
  1. #4
    Hi mate, take some photos and show us so we can 100% confirm but also check this thread out for my explanation of lines = http://www.nissanpatrol.com.au/forum...-to-a-N-A-TD42
    Sounds like you have a water and oil cooled turbo...
    Here is my turbo below standard HT-18. Should be same set up as yours but show some photos to us anyway.
    Plate with two bolts is your oil feed.
    The banjo bolt just below that in the photo is the water feed.
    Hole on bottom of turbo is your oil drain and the hole at the back of the turbo (closest to block) is your water drain.
    Check out the DIY thread in the link above and that should answer a lot questions but feel free to ask anything else as I just recently did mine.
  2. The Following User Says Thank You to AB For This Useful Post:
    diiirtyGQ (10th April 2012)
