Page 4 of 52 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 517
Thread: Blocking the EGR Valve
  1. #31
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    Yeah, 316L or 304 stainless would be the go, I have access to plenty 1mm thick.
  2. The Following User Says Thank You to the ferret For This Useful Post:
    claw45 (9th September 2011)
  3. #32
    Patrol Guru Timbo's Avatar
    East Melbourne
    I have seen a few people around various forums asking someone to do the whole job for them. It might be worth trying I guess. I thought about doing it but the majority of 4wd owners are DIY'ers and I didn't really see much sales in it.
  4. #33
    Sep 2010
    on the coast W.A.
    Ha Ha Timbo, I'm afraid my days under the bonnet are just about over, however I have the gear and could tool up for a batch.
    It'd be easier to grab one from the letter box than sourcing the material and then having to make one eh?
    then just back off the nuts, slide it in, tighten er up and ya done. cheers.
  5. #34
    Expert RustyNails's Avatar
    Morley - Perth WA
    Is 1mm thick enough?
    Western Patrol Club member #27
    2.8TD GU --> The Red Rocket
  6. #35
    Sep 2010
    on the coast W.A.
    yeah I reckon, stainless is a lot stronger than steel and 1mm would take 100psi over that small area, I have 1mm and 1.6 anyway, a piece of jam tin would even do the job I'd say.
  7. #36
    Expert Chops's Avatar
    Oct 2010
    I was watching "Your 4x4" on Aurora channel two days ago, and they had a segment on the "Grenade GU". They had a guy from Berrimah Diesel on the show who commented on blocking the EGR to aid in solving that problem.
    1984 MK Anniversary Model, LWB,SD33,Air-Con,P/S,Straight Body,Minimal Rust.........Not Bad For Free
  8. #37
    Sep 2010
    on the coast W.A.
    Yeah I am concerned about dust entering the inlet manifold, so I will supply a glued on gasket with the "shim" to seal between the inlet manifold and the "shim", best to be on the safe side as dust is a sneaky enemy of any engine.
  9. The Following User Says Thank You to the ferret For This Useful Post:
  10. #38
    East Melbourne
    I have used 1mm stainless on mine. No dramas at all. It's a tiny area as Ferret said.
  11. #39
    Beginner Kreskin's Avatar
    Oct 2010
    Indeed it helps... By simply putting the shim in (or blind cap) the result is noticable...
  12. #40
    Expert Pete's GU3's Avatar
    Jul 2010
    Melb. east
    Quote Originally Posted by RustyNails View Post
    only sounds thick enough to wrap my chicken schnitzel sandwich in ??????????????? i dunno
