Results 1 to 10 of 14
Thread: exhaust temperature
    May 2011
    exhaust temperature
    Hi
    Can anyone tell me what temperature I should have on my pyro gauge ?
    running a zd30 3in exhaust with dawes and needle valve egr blocked and a auto.
    With a load of 3 tonne pulling up a hill , the pyro reads 650 but most of the time 450 to 500.
    Is this good or bad ?
    Thank you in advance
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    Take ya foot off when it gets ta 500 max mate.
    Cheers , ferret
    What boost are you running?
    I agree with Rod, lift off when you see 500-550 (post turbo).
    Tony
    Sep 2010
    on the coast W.A.
    Yav done most of the mods mate and that's good on the ZD30, but if ya pull it at 500 plus for extended periods, ya gunna melt number 3 piston, keep ya foot off or wind it back a bit, as Tony says, what boost are you running?
    Cheers ,Ferret
  5. #5
    May 2011
    boost is 12-13 at 2000rpm max is 15-16 at 3500rpm or is the turbo spooling up to quick ?
    all new to this so not sure if the dawes and needle valve is set up correctly.
  6. #6
    If the turbo is spooling up too fast the boost will spike past maximum boost briefly before settling back to where it should be.
    Tony
  7. #7
    Feb 2012
    great infor guys helped heaps
  8. #8
    Expert Shaunous's Avatar
    Jun 2011
    Eagleby, QLD
    Quote Originally Posted by YNOT View Post
    Tony
    Do you think the same goes with the RD28t engine, I've always backed off around the 550 mark, but i've just always been scared that this is to much, it only really gets that hot driving up a long steep hill like the range on the Pac HWY around Byron, i've never seen any figures anywhere to go by, so i've never been positive. I've still got standard boost and standard exhaust, although a 2.3/4 beaudesert exhaust is my Xmas present, and then i'll up the boost a little, max it gets now as standard is 8.5psi.
    Cheers,
    Shaun...
    1998 GU - RD28t > TJM Bull Bar > Dual Batteries > Boost & EGT Gauges > Turbo Timer > Minor Engine Mod's.
  9. #9
    is temp is centigrade or faherhiet???
  10. #10
    Jun 2011
    Eagleby, QLD
    Always Centigrade in Australia thanks...
