Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Repairing Rust on your 4x4.
    DIY - repairing rust on your 4x4.
  2. The Following 4 Users Say Thank You to AB For This Useful Post:
    ahimz (11th November 2013), damaverick (5th October 2012), SammiGQ (19th March 2012)
    Nov 2010
    how do you spray the car afterwards so that it looks good? I canīt get a good result!
    Oct 2010
    Seems a bit simple for a proper job ok for a quick bog up tho'
    Nov 2010
    yeah thats exactly what i was thinking
    Feb 2011
    useful tip, does make it look easy tho, i find painting with a can hard if your doing a larger area the job looks striky
    Feb 2012
    cheers! I've got a bit of this to do soon!
    Beginner Dapple's Avatar
    Feb 2012
    Melton West, Victoria
    Great video I hope there are more like this
    What would you be if you were attached to another object by an incline plane wrapped helically around an axis?
    Screwed.
    This will definatley help me in the future. It's one thing I haven't really attempted yet.
  10. #9
    I am doing rust repair on my bonnet this weekend so this is a great video thanks for your help!
  11. #10
    Heres a few tips i have used when blending in rub the area back around the repair using a 1000 -1500 grade paper wet and use a retarder thinners helps the blend in.
    I always use a rust proofing behind the repair otherwise it will come back twice as bad.
    Not a fan of bodgie bog jobs personally i would replace the rusted sections with new metal.
    As for lines in the paint job usually i see that when not enough thinners is used i usually have a 70/30 mix with acrylic paint.
    Or the job is in the sun and 2 hot.
    But if it is acrylic a rub down with a fine grade paper using a block and soapy water afterwards to flatten out the surface then a polish usually brings out a nice finish.
