Results 1 to 10 of 17
Thread: What turbo to fit to a 4.2 diesel ?
    Expert makeitfit's Avatar
    Aug 2011
    Aberporth beach, west Wales, UK
    I've just signed up and wonder if you guys can advise
    My Y60 Patrol 4.2 diesel is NA so I want to fit a turbo. DIY but don't know which one to go for. Is there a favourite you can suggest. I will be mainly offroading the beastie and love loads of grunt
    I've got a mate who can make up the manifold and then a 3" exhaust
    Y60 Patrol 4.2 d SWB in puke green
    2" body lift, 2" pedders suspension lift, 35" Simex muds on excel 16" alloys, needs a turbo :/
  2. The Following User Says Thank You to makeitfit For This Useful Post:
    madchris (2nd March 2012)
    Banned
    Try this link mate..... It should be able to answer your question & give you some handy info & tips on DIY fitting.....
    http://www.nissanpatrol.com.au/forum...-to-a-N-A-TD42
    Expert GUte's Avatar
    Perth
    Garret gt2860rs with a .64 turbine housing are well suited and spool up nice and quick.
    Or Mitsubishi td05 16g which is the preffered choice of a well known diesel tuner here in WA, this is what I will be upgrading mine to when the time comes
    Aug 2011
    Nice one guys, just what I was looking for
    Loads to read on that link and now a shopping list too. Better get some work done quick sharp as I feel a big spend coming on
    Let us know how you go mate, I just finished putting my turbo on my GQ TD42 so feel free to ask any questions along the way.
    I learnt a lot of "what not to do" experiences too so ask away to save some time and money!
    Quick tip, if your going to use the bung on the LH side of the engine block just above the engine mount for the oil feed then see if the bung will come out first before buying the braided hose.
    Aug 2011
    I had thought of doing a custom exhaust manifold rather than the TD lump of pig iron
    Also want to fit a big old intercooler some where. Probably go for top mount and fit a big bonnet vent lke the scoobies
    Does the fuel pump need turning up or modding in another attempt at more torque
    Expert TuffTD42's Avatar
    Feb 2011
    Central West, NSW
    I'm running the Garret 2871r .60 comp .64 hotside. Pretty happy with that set up but as usual want more so now looking at the 3071. I think ball bearing is the way to go. This will give you an idea of what the 2871 sounds like. http://www.youtube.com/watch?v=E8G3B3Q4Zkw
    You will need to get the injector pump tuned to suit the psi that you run. Mines been advanced & the fuel turned up to suit the 18psi the turbo's set at.
    The conspiracy theorists were right!
    Aug 2011
    That sounds broody ace
    Now I'm hooked
  10. #9
    Advanced Dirtydog16's Avatar
    Feb 2012
    Armstrong Creek, Qld, Australia
    G'day mate,
    Mine is a turbo my Motsons in Brisbane. They have a website you could check out.
    Mine was on the car before I bought it and has worked fine and I also got LPG injection which gave me a heap more power as well.
    Enjoy
  11. #10
    I thought about fitting a ballbearing turbo but after reading up on them i decided against it due to the high failure rate and cost to rebuild one.
    I fitted a .63 ar exhaust .50 compressor t3 t4 to mine with the manifold and fittings etc for under $1000 new and couldn't be happier.
    I also considered the 16g td05 mitsubishi with a 10cm exhaust heard good reports about them as well.
  12. The Following User Says Thank You to 97_gq_lwb For This Useful Post:
