Results 1 to 10 of 10
Thread: when do you need to replace oil pump 1996 gq 3.0 RX petrol
Threaded View
  1. #3
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Might want to get a pressure test done and get a few other items looked at mate - as per YNOT, it may not even be the pump, and increasing the oil rating (viscosity - specifically the first number in this instance) may not suit for wherever you are located - i.e. if you are somewhere cold, you need a lower viscosity rating for cold starts (5, 10 or 15), to allow the oil to flow, and hence you could be just compounding your problems by going a higher viscosity/weight oil - not to mention you have to change it more often!!!!
    All the best with it mate.
  2. The Following User Says Thank You to Bigrig For This Useful Post:
    daves mrs (8th October 2010)
