Results 1 to 4 of 4
Thread: gq auto woes
Threaded View
  1. #4
    You've got some strange symptoms there with the power light and park brake light coming on, you could have a short in the wiring or a bad earth.
    The 300rpm drop is consistant with torque converter lock up, not sure about the surging.
    Your alternator may have a faulty diode, it will still charge ok but will drain the battery when switched off.
    Tony
  2. The Following User Says Thank You to YNOT For This Useful Post:
    da' maverick (2nd August 2011)
