Results 1 to 10 of 10
Thread: Power to UHF
    Sep 2010
    Brisbane
    Power to UHF
    Hi,
    Forgive my ignorance on this but i have read that there is always a "hot" cicruit in the fuse box which you can wire your UHF into in order for it to be on without keys...Is this true ?
    I now enough that i don't know enough about this and will be looking for an auto sparky to do the job but would be good to at least look as if i know what i'm talking about to some degree !
    Any advice appreciated
    Sep 2010
    Off Shore on Macleay Island, Near Straddie
    Not sure, but I would imagine so. Get a test light and check the fuse box for a live circuit. I would imagine that the clock, or interior light circuit would be the way to go.
    TC
  3. The Following User Says Thank You to TOECUTTER For This Useful Post:
    Billsy (30th September 2010)
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    I have my uhf hooked up in order for it to work without keys, I just got the test light and when i found a live wire with the keys out spliced into it i hop into the 4b of a mornin and hear the uhf still goin one day ill remember to turn it off
    Patrol Guru Timbo's Avatar
    East Melbourne
    I think I wired mine straight to the battery. It's on when I want it on and it's easy to wire up.
    Just don't leave it on for hours and hours while the car isn't running.
    WA Wheatbelt
    23 Post(s)
    Quote Originally Posted by Timbo View Post
    I had mine wired up at the same time it was serviced and I'm pretty sure the mechanic wired it straight to the battery too. Mine's got a fuse attached to the wiring.
    Banned
    If you go direct of the battery & use an inline noise filter for a car radio (sold at supa cheap) you will get the least amount of noise through the UHF which is what your looking for here.
    Sep 2010
    Brisbane
    Thanks folks
    Have a dual battery set-up and don't have enough wire to get fomr the secondary through to the unit
    Had a look at the grommet on the drivers side to see if i could get through there but it's too hard to get to
    Based on the advice presented, i may just get a longer cable with an in-line fuse and pull it through the passenger side grommet as i've done with the antenna
    It's not going to be the quickest installation on record but i'm enjoying it and learning as i go
    Oct 2010
    ive wired both my uhfs direct to the battery through relays i used the switched wire from the cigarette lighter to power the relays when the ignition comes on i dont like them on when the keys out is all cheers
  10. #9
    Jul 2010
    Waterford West Qld
    Just one other thing that I haven't seen said, although most don't see it neccessary, I was advised to place inline fuse on both wires, I have also read this in top quality radio repiar manuals. I just can't remember exactly what it reduces the risk of (maybe negative short). But I have always done it and could look up why it is suggested.
  11. #10
    Oct 2010
    i was told that fusing both wires was to help protect the set if battery hookup was incorrect i always thought a diode would be easier
