Have a look at your ID plate Scott to find out what ratio you currently have. If you have 3.9:1 then 4.1:1 will put your gearing back to standard with the 33's on.
Keep in mind the front locker will need to be swapped over and GQ LSD's are bigger and stronger than GU LSD's.
Tony
