Index to Useful Threads as started by YNOT (Tony)
To have another Item added to this Index post a reply with the Subject and Link
ZD30 and RD28 Engine protection modifications ;http://www.nissanpatrol.com.au/forum...ghlight=gren02
Sway Bar link Pins;http://www.nissanpatrol.com.au/forum...light=swaylink
CV and front Wheel Bearing Pictorial ;http://www.nissanpatrol.com.au/forum...wheel+bearings
Diesel Gas ;http://www.nissanpatrol.com.au/forum...ht=kitchener01
Speedo Correction Gears ;http://www.nissanpatrol.com.au/forum...peedo+gearTony
GQ/GU Child Anchor Points ;http://www.nissanpatrol.com.au/forum...+anchor+points
Getting more Power from RB30S ;http://www.nissanpatrol.com.au/forum...highlight=rb30
Testing and Cleaning MAF Sensors ;http://www.nissanpatrol.com.au/forum...highlight=rd28
Plastic Engine Fans Cracking ;http://www.nissanpatrol.com.au/forum...ghlight=blades
ZD30 Replacement Intercooler Options ;http://www.nissanpatrol.com.au/forum...ng+intercooler
Fuel Consumption Thread ;http://www.nissanpatrol.com.au/forum...el+consumption
GU 5th Gear Issues ;http://www.nissanpatrol.com.au/forum...04-GU-5th-Gear
Exhaust Back Pressure explained ;http://www.nissanpatrol.com.au/forum...-Flow-Velocity
Fitting intermittent Wipers to a GQ that had standard Wipers ;http://www.nissanpatrol.com.au/forum...k-without-them
GU Sub Tank Issues ;http://www.nissanpatrol.com.au/forum...k-light-issues
Electronic Rust Proofing ;http://www.nissanpatrol.com.au/forum...lectronic+rust
Fixing GQ/GU Auto Hubs;http://www.nissanpatrol.com.au/forum...Q-GU-auto-hubs
Preventative Maintenance;http://www.nissanpatrol.com.au/forum...ht=maintenance
Reading & Erasing GU Patrol fault codes;http://www.nissanpatrol.com.au/forum...eading+erasing
How to Insert a Nutsert without a Tool:http://www.nissanpatrol.com.au/forum...ng-the-tooling
